Condensation On Outside Of Windows Between Window And Screens - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2010, 04:00 PM   #1
Condensation on outside of windows between window and screens
I had new Hawthorne double hung windows with low e argon gas installed about 5 months ago. Every time it rains, there is condensation on the SOME of the windows, between the screen and the windows. I know there should be some water on the windows (after all it's rained), but it is now happening even when its not raining now. It takes about 6 hours for my windows to clear up; before that we cannot see through them at all. Example: On one window in my bedroom, the top pane is completely covered in condensation, while the bottom pane is totally clear. It bugs me to no end! What can I do?
Kelcala is offline   Reply With Quote
Old 08-12-2010, 04:36 PM   #2
Rewards Points: 1,910
It's likely that it's caused by the humidity outside and the Air conditioning cooling the outside of the glass to the dew point. It's been a very humid summer here and I like my house cool so I see that a lot in the mornings (the cooler nightime temps let the glass cool off more and the outside air is closer to the dewpoint temp).
You can set your A/C to a warmer setting so the glass isn't as cold. You can install insulated curtains and keep them closed at the times you know are problematic. You can adjust your A/C supply registers so they don't blow towards the windows so the glass doesn't cool as much.
Old 08-13-2010, 07:59 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
For the top to fog and the bottom to be clear I would think you have either:
A. An AC outlet blowing directly on that upper window.
B. A considerable air leak between the two sections that is admitting cold air from the house out to the exterior surface of the upper section.
PoleCat is offline   Reply With Quote
window screens how to remove and put back twinkenator Building & Construction 5 07-07-2010 11:49 AM
Replacing screens on Anderson windows sherwood Appliances 1 01-25-2009 02:42 PM
How hard to replace window screens? TomBrooklyn Building & Construction 4 01-04-2009 09:03 AM
Andersen Window Screens jte1130 Windows and Doors 2 04-28-2008 02:23 PM
Removing/replacing window screens gt2003 Building & Construction 5 09-21-2005 05:51 AM
