Condensation On New Windows - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 11:34 PM   #16
Tom Struble's Avatar
Rewards Points: 2,002
they are probably finei just notice when you see this its at the bottom and at the meeting rail
Tom Struble is offline   Reply With Quote
Old 09-22-2010, 03:52 PM   #17
Tom,
So you mean: if I see condensation on the interior side of my windows' glass surfaces, and if the condensation is at the bottom and at the "meeting rail", then it is ok?
correct?
Thanks!
Hexar is offline   Reply With Quote
Old 09-22-2010, 06:58 PM   #18
Originally Posted by Hexar View Post
Tom,
correct?
Thanks!
I didn't notice where you lived, but you will get condensation. Sometimes it can be controlled by using exhaust fans and limiting the source of the moisture. I wouldn't worry too much unless it forms ice on the inside or doesn't clear up after the sun hits it. There's more of a science to it but that's a basic tip.
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Hexar (09-22-2010)
Old 09-22-2010, 08:29 PM   #19
Tom,
correct?
Thanks!
no that not what i mean,your problem is probably high humidity,but the coldest part of your windows is at the places you see the condensation
The Following User Says Thank You to Tom Struble For This Useful Post:
Hexar (09-22-2010)
Old 09-22-2010, 10:59 PM   #20
Thanks Mrgins,
I got hold of a simple "humidity meter", and the humidity in my house, near the windows, is about 50%. IS this too high or normal?
I will try to install a kitchen range hood fan this weekend and see if this improves or not.
Thanks again!
Old 09-22-2010, 11:00 PM   #21
Got it.
Thanks Tom!
Old 09-23-2010, 01:08 PM   #22
Rewards Points: 156
http://www.rlcengineering.com/win_chart.htm
Here is a nice graph that will show you when to expect condensation on your windows. To be safe you will want to reduce your indoor RH to about 35%. Anything under 30% and you risk to dry of air that may contribute to certain virus spreading and sore throats. This is what I had to do to eliminate our window condensation.
creamaster is offline   Reply With Quote
Condensation on Windows (PICS) - Advice Please livinginthepark General DIY Discussions 16 12-20-2010 07:35 AM
Condensation on outside of windows between window and screens Kelcala Building & Construction 2 08-13-2010 07:59 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
aluminum windows condensation smalan Building & Construction 2 01-02-2009 07:51 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
