Condensation In A Converted Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 03:49 PM   #1
Condensation In a Converted Attic
We have a small room in our attic that has been converted into a bed room. I noticed condensation on the walls when it's cold outside. The RH is 65% at 62 degrees. The rest of the house (1st floor) is 35% RH at 65 degrees. When I use a dehumidifier to bring the RH down to 50%, the room is fine. No condensation what-so-ever. Why is this room humid? We've had the house for 16 yrs and the problem has just recently appeared. We got a new oil burner 4 yrs ago. It is stronger than the old one and keeps the room warmer. In the past, we used a space heater for extra warmth. We have a forced hot air system. Could this be the source of the moisture? The attic itself is well ventilated. I'm pretty sure it's not the insulation trapping moisture. I think something is adding extra moisture into the room. Any thoughts? This is the second yr I'm dealing w/ the problem. Over the summer I replaced an old ridge vent and added a new one in the hopes of solving the problem.
Setsuna_F_Seiei is offline   Reply With Quote
Attic condensation problems vVvAiyanavVv Roofing/Siding 10 02-04-2011 08:55 PM
Condensation on attic A/C ducts unlvrebel HVAC 1 08-29-2010 05:31 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Attic converted to second floor rebuildergirl HVAC 28 06-03-2009 10:35 PM
attic condensation darren Roofing/Siding 11 01-24-2006 10:27 PM
