Condensation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 09:42 AM   #1
hello, i live in wisconsin and my house is seven years old. i've been told that new houses are built to tight. i have so much condensation on my crank out windows that i have to wipe them dry everyday, sometimes it forms ice and it causing the wood to rot. what can i do to remedy both problems
koby1 is offline   Reply With Quote
Old 01-22-2011, 01:46 PM   #2
ccarlisle's Avatar
Ventilate. If you have a forced-air heating system, turn the fan on and keep it on, then buy a dehumidifer.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 01-22-2011, 02:57 PM   #3
Rewards Points: 5,336
What type of heat do you have?
Is there a humidifier on it?
Does it vent up the chimney or out a wall?
What's the humidity levels in the house?
Are the baths vented to the exterior?
Is there a kitchen exhaust fan?
Any humidity producing features, like an indoor pool, fountain or hot tub?
Does the house have an air exchanger?
Condensation between foamboard and fiberglass insulation zeetwoeight Building & Construction 4 01-17-2011 07:38 AM
Condensation line flowing lots of water (pics inside) Volleyballer[G8 HVAC 12 07-26-2010 12:46 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
