Conctete Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 10:53 AM   #1
Conctete floor
I am pouring a concrete floor in my basement. My questions are, do I have to put plastic over the dirt floor first, how thick should I pour the concrete and do I pour it right up against the cinder block walls?
almostdone is offline   Reply With Quote
Old 02-25-2008, 01:16 PM   #2
MA licensed remodeler
iremod's Avatar
Hi almostdone,
There is an article here that addresses most of your questions.
If you like Bob Villa then check out a multipart video series here that shows the prep and pouring of a concrete floor in an existing basement. Of course they are sparing no expense in this particular project (concrete pump truck, professional install, etc.)
As far as pouring right up to the cinder-blocks, that should be fine.
iremod is offline   Reply With Quote
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 11:58 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 10:53 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
