To ConcreteMasonry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2007, 06:12 PM   #1
Rewards Points: 150
Question
To ConcreteMasonry
A few years ago, a 'friend' textured our concrete slab and 'stained' it.
Now he is no where to be found [duh.]
The texture varies [high/low, lots in some spots, other spots completely smooth] throughout the space.
The stained surface is wearing off, leaving areas that are either completely white, or look like a bottle of bleach has been dumped on it.
What options might be available to a DIYer to reclaim the floor? I'm not opposed to the texturing and staining, but what is there is not working.
shapeshifter is offline   Reply With Quote
Old 03-24-2007, 08:12 PM   #2
Rewards Points: 1,232
I am not he, but the deal with stained and textured concrete is thus: You stain the concrete to achieve a color. You then seal the stain to protect it. You must then protect the sealer with wax, since it is much easier to strip and re-wax a floor than it is to re-seal it.
It sounds as though your floor was stained and sealed, and the sealer has reached it's normal lifespan without the protection of wax.
Your alternatives are to strip the sealer, clean the floor, re-seal it and then apply wax (multiple coats, the more the better), or to start over from scratch.
Tscarborough is offline   Reply With Quote
Old 03-24-2007, 10:36 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Glad TS caught this before me since he knows more about stains, seals and architectural treatment.
concretemasonry is online now   Reply With Quote
Old 03-25-2007, 05:03 PM   #4
Rewards Points: 150
Unhappy
TY both for responding.
Is there a way to remove all the finish, smooth and even out some of the texture and then start over with the stain, seal-coat and wax?
Could you somehow wet-grind the floor down?
I'll try to post a picture, but believe me, it won't be pretty.
Old 03-25-2007, 05:24 PM   #5
A photo would certainly help.
Old 03-26-2007, 06:43 PM   #6
Rewards Points: 150
Warning, viewer discretion is advised.
The following images are for mature audiences only.
Here are a couple of images of the floor. It was supposed to look like terra cotta tile. Maybe I wouldn't mind the texture so much if the color was more consistent. I spoke with my husband and we both understood that the waxing was an option, not a necessity. So, yes, we are probably responsible for most of the outcome. Now we need a solution.
Old 03-26-2007, 08:13 PM   #7
One closeup would be better, but I can get the gist from those. Is there any way to find out exactly what sealer he used originally? I will tell you that removing most sealers is not a fun task, but with some, simply recoating it will rectify most of the issues.
Old 03-27-2007, 01:11 PM   #8
Rewards Points: 150
We do not have any of the sealer so we do not know what type/brand was used. Any other suggestions? Can we get back down to the cement somehow?
Old 03-27-2007, 07:48 PM   #9
It is almost easier to break it out than it is to remove most concrete sealers. Could you take a closeup(2-3 feet) of one of the white areas?
Old 03-27-2007, 09:15 PM   #10
Rewards Points: 150
Cool
I will work on it. Having upload issues
Masonry drilling stenton Building & Construction 16 02-15-2007 12:21 AM
Basement flooring choices Brik Building & Construction 23 01-27-2007 02:38 PM
