I am not he, but the deal with stained and textured concrete is thus: You stain the concrete to achieve a color. You then seal the stain to protect it. You must then protect the sealer with wax, since it is much easier to strip and re-wax a floor than it is to re-seal it.
It sounds as though your floor was stained and sealed, and the sealer has reached it's normal lifespan without the protection of wax.
Your alternatives are to strip the sealer, clean the floor, re-seal it and then apply wax (multiple coats, the more the better), or to start over from scratch.
The following images are for mature audiences only. :laughing:
Here are a couple of images of the floor. It was supposed to look like terra cotta tile. Maybe I wouldn't mind the texture so much if the color was more consistent. I spoke with my husband and we both understood that the waxing was an option, not a necessity. So, yes, we are probably responsible for most of the outcome. Now we need a solution.
One closeup would be better, but I can get the gist from those. Is there any way to find out exactly what sealer he used originally? I will tell you that removing most sealers is not a fun task, but with some, simply recoating it will rectify most of the issues.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
