Old 11-24-2006, 04:52 PM   #1
Default Concrete walls on wooden joists
We have just moved in to a new house (built 1955) and we have discovered that the interior walls are breeze block (17" x 4" cement blocks). Very heavy. No problem downstairs on concrete floors but we were astonished to find that the upstairs dividing walls are built directly on 7" x 2" wooden joists with no load-bearing walls below them, in fact nothing below them. I calculate the longest wall is around 1350kg over 2.7 m which is a load of 500kg per metre over two thirds the joist length. I think this is way too much for the joists but my husband thinks there is nothing to worry about. Any thoughts?
stonehanger is offline   Reply With Quote
Old 11-24-2006, 06:01 PM   #2
concretemasonry's Avatar
Since you refer to "breeze blocks" you may be from the U.K. or the Appalachian (sp?) area of the U.S.
Are the breeze block mortared or are they just plastered for an interior non-bearing wall? If plastered, they may be just a dead load (mass) and not a bearing wall. This application is used frequently to provide internal thermal mass and minimize the a mount of heating capacity required.
If the block are mortared, the span is very short in comparison to the wall height above and there could really be very little load on the joist due to the "arch action" of a masonry wall.
I suggest you contact a local engineer to see what the entire structural configuration consists of and how everything works together.
Since your description does not fit the stereotype U.S. condition of construction, which is not the same as the majority of the developed world, you need local advice on your condition.
concretemasonry is offline   Reply With Quote
Old 11-24-2006, 06:15 PM   #3
Thanks for the reply. Yes, we are in the UK. The blocks are mortared. We have taken down one wall that was separating a bathroom and toilet, it was sitting directly on the floorboards over the joist and came down fairly easily. It was doing nothing to support the ceiling joists above (there was a gap). If the dividing walls were supported at each end by a load-bearing wall below I wouldn't be so concerned, but the walls are not keyed in to the exterior wall and they extend only part way along the length of the joist therefore loading it unevenly.
Old 11-24-2006, 06:26 PM   #4
You observed and removed a wall that was not loadbearing.
Trial and error is not the best way to find out what consequences there are when you remove a wall.
The fact that the walls were not keyed into each other is usually not critical, but it is important in the big picture.
The U.S. approach (limited structurally) is to stack up things and not be that concerned with the interaction of portions of a structure. Your home was not built that way, so you would be well advised to look to a professional in your area that is a little beyond the "stack up" lightweight construction philosophy. Your home may well be adequate or actually beyond the performance of someone not familiar with that type of construction.
More On This Topic
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be taking you through the process for preparing our wall. The wall that we have here is made of cinder blocks. A lot of times along these mortar joints it will crack and/or leak so... Read More »
Building a sculpture out of plaster is one way for beginners to learn to sculpt. The process is not complicated and the materials needed to build a plaster sculpture are readily available. Read More »
What is an I-Joist?
What is an I-Joist? by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
Taking the time to properly prepare your walls for papering will be well worth it in the long run. New wallpaper will add a fresh look to any room and will last for many years to come if the walls were prepared before the wallpaper ever goes up. So... Read More »
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 11:38 AM
basement framing, walls parallel to joists DIY4EVER Building & Construction 8 06-06-2007 05:08 PM
Insulating Joists over concrete sandyman720 Building & Construction 5 05-24-2007 02:52 PM
Insulating Joists over concrete sandyman720 Flooring 0 05-22-2007 03:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
