Old 02-11-2013, 11:17 AM   #1
"You can do anything"-Mom
brockmiera's Avatar
Concrete walls not square - How to frame
Ok so I started framing my basement this weekend. I have framed the bathroom walls parallel with one another and the room is perfectly square (diagonals)
I was laying out the walls for the back room and found that if I frame a wall square with my other two walls it will end up about 1/2" away from the concrete wall. Not usually I wouldn't worry about it except there is a window in the middle of that wall.
Now Im thinking if I frame the wall square with the other two then my window sill will be skew. How should I handle this?
Concrete walls not square - How to frame-framing-layout.jpg   Concrete walls not square - How to frame-corner-.jpg   Concrete walls not square - How to frame-corner-b.jpg
brockmiera is offline   Reply With Quote
Old 02-11-2013, 11:57 AM   #2
GBrackins's Avatar
I'd frame it square like you shown in your sketch. where the window is located I'd frame the opening perpendicular to the back wall (stud wall). one side of the window framing would be a little longer than the other side, no big deal, just take accurate measurements.
my humble opinion
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
brockmiera (02-11-2013)
Old 02-11-2013, 12:02 PM   #3
I never framed anything in my life (pretty much) but I think you should keep the window sill even and not worry about the corners of the walls being square. The window sill skew would be more obvious.
Dorado is offline   Reply With Quote
The Following User Says Thank You to Dorado For This Useful Post:
Old 02-11-2013, 12:13 PM   #4
brockmiera's Avatar
The thing is it will only be about 1/8" difference across the width of that window. I have no doubt that I will be the only one that will know. Now I have to decide if knowing the walls aren't square is worse than knowing my sill is skew.
Any pro framers out there ever run into this? I'm sure there are. How is it handled in the field?
I think I"d rather have the room square. But I'm not framing it until tonight so I'll hold off for others to chime in.
Old 02-11-2013, 12:22 PM   #5
In the photo it looks like the window is more than 1/4 the width of the room, but now I see you used graph paper and you're saying it's 1/4 the width, so I'm not so sure now. I know a corner of my bathroom wall is pretty far off square but I didn't notice it until I tried mounting a square toilet paper holder there. If you're putting anything square in the corner, then definitely keep the walls square.
Old 02-11-2013, 12:28 PM   #6
brockmiera's Avatar
Yeah the photo might be throwing you off. The window in the third picture is in the bathroom. That wall is good to go. The window that I am concerned about is about 12' to the right of that one in the back room (not a bedroom because of improper egress) You can just see the corner of it in the second picture. That wall is 11'-6" and the window is 32" wide. So it is 23.19% of the wall. Just under 1/4 of it. So I guess by that math it would be 1/16" of an inch out of square for the window sill. I guess with those measurements I've made my mind up.
Old 02-11-2013, 12:52 PM   #7
Newbie Bill
If you go with the room out of square, it may show up with your flooring and/or ceiling choices.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
The Following 2 Users Say Thank You to drtbk4ever For This Useful Post:
brockmiera (02-11-2013), oh'mike (02-15-2013)
Old 02-11-2013, 12:55 PM   #8
brockmiera's Avatar
Yeah that was also a concern. For now we are doing carpet in that room so no problem there. Drywall ceiling so that would make it a little tougher. I'm just going to frame it square and worry about those window returns later.
Old 02-14-2013, 12:01 PM   #9
brockmiera's Avatar
Well I ended up framing the room out square and just as I thought I was only 1/16th of an inch off. I'd say that is acceptable.
The Following User Says Thank You to brockmiera For This Useful Post:
Old 02-14-2013, 10:48 PM   #10
Aren't you able to get any beer out there to drink?
It is very rare to find anything square, let alone level, flat, plumb, whatever.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Old 02-15-2013, 12:09 PM   #11
brockmiera's Avatar
Yeah we can get beer but I'm a whiskey man!
Cold storage: Drywall over exterior poured concrete walls? TomU Building & Construction 3 11-19-2012 01:31 PM
Frame Concrete Half Wall in Basement VikingDinKC Remodeling 6 03-09-2012 09:31 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 01:44 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 04:07 PM
