Old 07-13-2011, 04:57 PM   #1
Concrete walls
I'm about to begin finishing my basement. A month ago I had a flood and the concrete walls are showing signs of mold. I was told to sand the walls and apply Drylock, before framing. I just want to know is this acceptable or are there other steps I should consider before framing.
manny125 is offline   Reply With Quote
Old 07-13-2011, 05:02 PM   #2
Concrete walls
I would wash the walls and kill the mold. I see no reason to sand the walls unless you want mold spores airborne.
Ron
B. Franklin 1759
Old 07-13-2011, 11:03 PM   #3
Moderator
Concrete walls
Drylock will only send the moisture elsewhere to enter your basement. A little reading: http://www.buildingscience.com/docum...gs?full_view=1
Gary
Clothes taking longer to dry?
floor cover opinion - concrete slab floors with cinderblock walls suevwbug Flooring 6 05-09-2011 10:22 PM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 01:24 PM
Wet Concrete Walls: Painting apartments in China szstevo Painting 9 01-03-2010 11:04 PM
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 01:04 PM
Concrete slab with hot water heat- Moving walls skizsam Building & Construction 16 04-06-2009 03:08 PM
