Concrete Wall Tabs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 01:21 PM   #1
concrete wall tabs
Getting ready to stud out a basement which has poured walls. Most of the tabs for (I'm assuming) holding the forms together are still there. The only problem that I see is that they transfer the cold weather through them. I also guess that some of them may be right where a stud will be located.
Is it o.k. or recommended to remove them and if so - how? Also, if I remove them, do I need to put a sealer over the area? I don't have any water issues (leaks) now and I don't want to start any!
Thanks,
Rick
upinsmoke is offline   Reply With Quote
Old 04-26-2010, 06:49 PM   #2
Concrete & Masonry
Rewards Points: 548
The wall ties are perferated so that they will break away easily at the surface when tapped sideways with a hammer. As for sealing, I wouldn't be concerned, as they should already be sealed from the exterior.
jomama45 is offline   Reply With Quote
Old 04-26-2010, 07:10 PM   #3
Rewards Points: 5,336
Or... you can impale 2" foamboard on them and stud out the wall in front of the foamboard.
I would think there's a small chance they're sealed on the exterior, very small.
Ron
Old 04-26-2010, 07:19 PM   #4
Concrete & Masonry
Rewards Points: 548
Originally Posted by Ron6519 View Post
Or... I would think there's a small chance they're sealed on the exterior, very small.
Ron
Maybe not, but if it has a sprayed on damproofing, they should be sealed up OK. I can't see any benefit to leavign them on from a water leakage standpoint.
Old 04-26-2010, 07:19 PM   #5
I have a few in my 50's basement that allowed a trickle of water in during repeated heavy rain in March
This was the most rain on record since 1885
If you are going to remove them I would seal them before you close it up
Old 04-26-2010, 07:44 PM   #6
You might be projecting a universal competence in foundation contractors that does not exist. You might do this as a matter of course, but others are not so diligent. By the time the issue raises it's head, these guys are long gone.
Ron
Old 04-27-2010, 12:46 PM   #7
Thanks all. Since about 75% of the basement is underground and, to date, I have had zero water in the basement (fingers crossed x2), I have to believe there is at least some sealer on the outside. However, if there is any doubt, I may just seal around them whether I break them off or not. Or, should I only seal around the tabs that need to be broken off?
So, who's got a recommendation on what to put on there to seal them up? I already have two coats of Dri-Lok on the walls.
Rick
Old 04-30-2010, 02:45 AM   #8
BUMP for sealer info
Tried to send a PM but apparently haven't posted enough (yet) to do so. From previous posts - sounds like I should seal around the tabs (or where the tabs used to be) so wadda I use? A caulk tube of ordinary concrete sealer? If I'm going to do it, I'd like to use a product that has a history of success with our expertistas
Thanks,
Rick
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
insulate concrete wall above grade? bcbud3 Remodeling 5 02-13-2010 06:50 AM
Depth of the flower garden next to the concrete wall ? cprao Landscaping & Lawn Care 12 10-28-2009 10:12 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
