Concrete Wall Structural Strength - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 09:50 PM   #1
Looking for advice if a concrete wall will lose structural strength if an opening is made larger vertically. Here are the conditions
10" Concrete foundation wall 14 feet high.
wall supports 3 14x26 I beams ( garage above)
42" x 42" opening was made during the pour.
opening is 5.5 feet from top and 5+ feet from the footer.
right side of Opening is 12" from corner (inside) and 22 " from outside
one of the I beam is cut into pockets about 6" offset from the left side of the opening.
I want to cut the opening big enough to frame in a 36x80 door. Any advice. Thanks.
geiser is offline   Reply With Quote
Old 03-11-2008, 06:19 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,....
If the I beam is Not above this opening,...
And,....
You install a Steel Header above the Door,.....
I don't see a Problem.....
Old 03-11-2008, 10:09 AM   #3
so-elitecrete
Rewards Points: 150
if there's not a supporting,,,
beam above, i'd do it & not worry a bit,,, 14' - 6' 8" = 7' 4" remaining 10" conc,,, enuff to hold 2 elephants in my house,,, the only suggestion i'd make is to diamond saw the cuts rather'n use a chipping gun which might cause microfractures in the wall reducing its supporting strength.
so-elitecrete is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 05:17 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 05:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
