Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2006, 02:29 PM   #1
concrete wall
I have a concrete block wall building built on a slab. The first row of block was attached to the slab with mortar. There is no rebar going through the slab into the block. Am I in trouble? If so is there a way to correct this.
glseagraves is offline   Reply With Quote
Old 06-15-2006, 07:09 PM   #2
IHI
FWIW, alot of the older structures never had any mechanical fastners between the slab/block. Most would let the slab cure for a day or more then come back and motor the block into place. Today we personally use a combination of wet setting the block-putting them in before the concrete is completely hard and using bent rebar tied to the perimeter rebar that sticks up through the slab and set the block over top of it then fill the void with mortor.
I dont think I'd lose to much sleep over the deal since all of the weight of the structure is pressing down on bottom course of block so it'd take quite a blunt force to move it. If all else fails do like the jacklegs do...caulk it LOL
Website
IHI is offline   Reply With Quote
Old 06-15-2006, 09:13 PM   #3
General Contractor
joasis's Avatar
I won't say that is the best way to do it, but it has been done that way for years...if a slab is poured without rods up, there isn't much else to be done except continue....the strength of the mortar set block bond may surprise you.
joasis is offline   Reply With Quote
Old 06-16-2006, 09:58 AM   #4
Contractor
Brickie's Avatar
Rewards Points: 79
No, you are not in trouble. I wouldn't worry about.
Brickie is offline   Reply With Quote
Texture Coating for a New Concrete Block outside Wall scholin Painting 2 12-01-2007 07:03 AM
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 06:17 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
