Concrete Walkway Separators - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 12:20 AM   #1
Rewards Points: 1,062
Question
concrete walkway separators
i need to build a walkway. every concrete walkway i've seen is divvied into something like 4' slabs with something like 0.5" separation between that's filled with something i can't identify. what are those separator things?
Old 08-23-2010, 04:49 AM   #2
Rewards Points: 4,538
1st understand the REASON the conc's divided is to allow it to crack where WE want it to crk,,, conc likes to be square to a point - placing too large a piece w/o designed cracking ( contraction jnts ) tells the conc we either don't care, we're ignorant, or, in the case of our diy garage floor bldr who ' didn't have time ' to cut jnts, stupid to the point he hurt himself.
what you see is beaverboard or paperboard impregnated w/asphalt cement/water emulsion,,, its called ' expansion joint ' &, once you know what you're doing, isn't necessary,,, most do not even if they do it for a living so they'll blindly follow the engineer's plans rather'n going for change orders,,, note you won't find expansion jnt mtl on conc highways, runways, or aprons ( sidewalks for airplanes & cars )
The Following User Says Thank You to stadry For This Useful Post:
amakarevic (08-24-2010)
Old 08-24-2010, 02:09 PM   #3
Question
thanks. what is the commercial name i should be looking for to buy this thing ? beaverboard ?
Old 08-24-2010, 02:50 PM   #4
Rewards Points: 156
What he's saying is, you don't need it. Use one of these:
http://www.concretenetwork.com/photo...roducts_25993/ while you're finishing after you've poured the slab. The concrete will crack in the groove, and noone will be the wiser.
moondawg is offline   Reply With Quote
The Following User Says Thank You to moondawg For This Useful Post:
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
concrete walkway... f8lyer8s Building & Construction 3 06-22-2009 08:43 PM
Concrete Walkway with Exposed Aggregate BTn5qsc2zB93ztGN9vJP Landscaping & Lawn Care 4 08-22-2008 08:49 AM
Get Peeling Paint off of Concrete Walkway BarrytheBuilder Painting 3 12-02-2007 08:46 AM
