Concrete Walkway... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 07:48 PM   #1
Umm.. U sure thats right?
concrete walkway...
Whats the easiest way to make curving in concrete? im using 1/2" ply that i cut kerfs in... keeps breaking... il post a pic of what im looking to do.. i was thinking of doulbed up luan... any thoughts?
you have to imagine that the tree is gone, and that the concrete is torn up... which it is, i just dont have an updated pic...
you can see the red line where i want the walkway to go...
f8lyer8s is offline   Reply With Quote
Old 06-22-2009, 07:54 PM   #2
pic failed will try again laterr...
its about a 10 foot section that gets wider then curves right about 45 gegrees into deck landing..
Best I could do.....
-----LLL (steps)
( LLL
\ l
\ l
l l
l l
Old 06-22-2009, 08:01 PM   #3
Concrete & Masonry
Rewards Points: 470
The best material for tight radiuses is 1/8" or 1/4" "Masonite", or hardboard. It comes in 4x8 sheets commonly, & can be ripped to 4", or whatever height you please. I cant see the pictures, but 1/4" should get you down to about a 2' radius, 1/8" even less, obviously. You could also attempt to soak the ply you already have in water. I can remember years ago, floating 1x4's in a few custumer's pools!
jomama45 is offline   Reply With Quote
Old 06-22-2009, 08:43 PM   #4
Didnt even think about that... its probably more rigid then luan... good call... cheaper too... thanks!
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Concrete Walkway with Exposed Aggregate BTn5qsc2zB93ztGN9vJP Landscaping & Lawn Care 4 08-22-2008 08:49 AM
Get Peeling Paint off of Concrete Walkway BarrytheBuilder Painting 3 12-02-2007 08:46 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
