Concrete Vs Interlock Paver Driveway In Cold Winter - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 07:47 PM   #16
Knucklez's Avatar
Rewards Points: 932
i see both in my neighbourhood (southern ontario). but if i were doing the project, i would price it out like this:
cost of me doing pavers vs. cost of someone else doing concrete
i can do the pavers myself because it is a simple job and easy to correct mistakes. concrete on the other hand is not easy to fix yourself and also not possible to pour yourself. nothing looks worse than a big crack down a cement driveway, so i would say this is a pro job only.
which ever is cheaper is the way i would go. .. course then the wife would have her say....
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
The Following User Says Thank You to Knucklez For This Useful Post:
concretemasonry (09-12-2011)
Old 09-12-2011, 08:59 PM   #17
concretemasonry's Avatar
Rewards Points: 2,626
Setting pavers is the easy part and is definitely a DIY project at your own pace once the base is compacted and leveled and the 1" layer of sand setting bed is screeded (not compacted) between the edge restraints. On a commercial job, it takes several laborers to deliver pavers fast enough to the setting area for each setter.
Dick
concretemasonry is online now   Reply With Quote
Tags
driveway
Asphalt Driveway Cold Patch and Sealing DIYguy2000 General DIY Discussions 5 04-12-2017 06:11 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Driveway and concrete repair cleogold Building & Construction 3 03-01-2011 12:21 PM
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
Driveway - pour concrete over granite curb? homeowner54 Building & Construction 4 06-09-2010 10:10 PM
