Concrete Vs. Crushed Rock For Setting Deck Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2010, 11:03 AM   #1
concrete vs. crushed rock for setting deck post
I'm building my 3rd deck (4th house)....been using the old standard method of packing dirt in the bottom to get the post square then filling with concrete. I'm always looking to improve on my methods and have been reading about using compacted limestone instead of concrete.
Any suggestions? This particular deck will only be 7 inches off the ground in 3 areas and then a raised area that will be 15 inches off the ground. Needless to say not very high. Looking for a quick method for setting posts so that I can frame the deck out.
Thanks,
Chris
Chris493 is offline   Reply With Quote
Old 05-04-2010, 11:27 AM   #2
I put concrete piers in & posts on top of that
Metal bracket attaches the 2
Gravel in the bottom & around the sides allow the posts to dry out
Sealing the posts in concrete will rot them long term
Can depend upon your soil/drainage conditions
Where are you located ?
Attached to the house ?
Old 05-04-2010, 01:06 PM   #3
not attached to the house and located in south Louisiana.
no drainage problems that i know of, the ground slopes well away from the deck area into a larger part of the yard, just hoping to find a less cumbersome method of installing the deck as i have at least 24 supports i need to put in.
Old 05-04-2010, 01:17 PM   #4
i dig hole ,tamp crushed stone, add deck plug, set post , backfill with dirt and stone mixed for solidity and drainage
The older I get the better I was
Old 05-04-2010, 01:21 PM   #5
tpolk.....deck plug?
Old 05-04-2010, 01:31 PM   #6
here they have premade concrete circles 6"-8" wide approx 3" thick to set posts on in holes
Old 05-04-2010, 03:36 PM   #7
Types of "instant" support
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
Deck Over Concrete Patio redhermes Building & Construction 10 06-18-2008 11:01 PM
Sagging concrete pool deck Immolate General DIY Discussions 1 06-11-2008 09:16 PM
Post in or post on concrete cibula11 Building & Construction 5 06-07-2007 09:39 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 07:55 AM
