#1 |
Concrete type for repair around ABS drain
Hello everyone!
I have no experience with cement so I come you for your expert advice. Any suggestions would be greatly appreciated. In order to install/anchor a new toilet flange correctly I plan to pour cement to fill in the space between the drain and the existing concrete. This will also prevent toilet leak from entering below the tile and slab. 1. Since the ABS turn is visible and only partially under concrete, can I pour concrete directly on to of the ABS? Or should I put a layer of gravel in between? 2. For concrete, which type should I use? Hydraulic water-stop cement? Anchoring cement? Quick-drying? Anchoring cement would seem to be the best choice to hold down the flange bolts but I'm concerned about its expansion properties putting pressure on the ABS turn. PICS |
| Display Modes | |
| Sewage type smell coming from bathroom shower drain | majorchamp | Plumbing | 29 | 06-25-2012 11:08 AM |
| What type of Stainable Concrete Filler Should I Use? | vcheez | Flooring | 1 | 01-13-2012 01:41 PM |
| moving shower drain - concrete basement | williamwiens | Plumbing | 9 | 01-13-2011 04:22 PM |
| Removed plunger type drain assembly but bathtub still wont drain. Please help | lydiarosestiles | Plumbing | 3 | 05-01-2010 12:59 PM |
| Do we have to break the concrete floor for a shower drain? | Mechelle | Plumbing | 41 | 07-30-2008 09:59 AM |
