Concrete Sweating Bad - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2008, 08:07 PM   #1
concrete sweating bad
Basement is almost 5 yrs. old. approx 1650 sq. ft. I have a wall facing north side that is approx 14' long that sweats bad. I painted it with dry lock paint , to seal it and it still is wet. of all the walls in basement no other north side walls are wet, just one area . basement is insulated with foam sprayed on joists around outside walls. In Michigan. any ideas or explanation?
big daddy-o is offline   Reply With Quote
Old 01-23-2008, 09:18 AM   #2
no one out here has concrete knowledge? Help out please
Old 01-23-2008, 12:35 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,...... There's plenty of Knowledge at this site,.....
Maybe you need to post alittle more Info,+/ or pictures........
Is this wall above, or below grade,..??
Condensation is usually caused by warm humid air meeting a cold surface......
Are you sure it's Condensation,..??..??
Or,....
Is the wall Leaking,..??
Old 01-23-2008, 01:36 PM   #4
When you tape a plastic square on the wall where is the moisture forming?? Underneath or on top of the plastic?
hhol00 is offline   Reply With Quote
Old 01-24-2008, 10:21 AM   #5
This wall is half under ground and half not . It is a north facing wall that is near, but not part of my daylit wall ( not a walk out but half wall with windows) I will either be crystalized(like frost) or wet to the touch, but not really dripping of the wall, and it 's not always this way. I caulked tha outside of sill plate thinking cold air was doing it Icaulked the areas where metal ties go through poured walls , all areas above in floor joist are sprayed foam, so i'm lost as to why?
Old 01-24-2008, 11:25 AM   #6
concretemasonry's Avatar
Rewards Points: 2,572
You must have poured basement and not block.
The interior surface of your wall is too cold if you have frost. Just moisture could be condensation.
I would suggest gluing 2" extruded polystyrene to the exterior and cover with a stucco-type finish. - While I was at it, I would dig down and insulate as much as possible make sure my backfill carried the surface water well away from the house.
concretemasonry is offline   Reply With Quote
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
