Concrete Sub-floor In Kitchen - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 11:09 PM   #1
Concrete Sub-floor in Kitchen
I have had a lot of problems trying to fasten something to the kitchen
sub-floor because it is concrete. The special screws they sell at the
hardware store do not work; the concrete nails do not work either;
all the special items I buy, I end up throwing away because they simply
do not really fasten anything. I hope you may have some suggestions
as to what type of special screw really works on concrete.
Thanks in advance.
Gabriel24 is offline   Reply With Quote
Old 12-19-2010, 01:39 AM   #2
Rewards Points: 1,092
What are you trying to lock to it? Maybe a mastic of some sort would work better than a mechanical fastener.
Old 12-19-2010, 05:24 AM   #3
Rewards Points: 4,750
evidently its harder concrete compared to other strengths,,, if conc screws aren't working, you may need drop-in's ( lags into lead or plastic expansive shields ) or mastic as klinger sez,,, caution for the future - holes're easier to patch than it is to remove mastic
Old 12-19-2010, 06:12 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,644
Ayuh,... I'm wondering if it's your Technique, rather than the fasteners...
I've had Great service from Tap-con screws...
Bondo is online now   Reply With Quote
Old 12-19-2010, 07:52 AM   #5
Rewards Points: 5,336
Thanks in advance.
The issue is with you, not the fasteners. You're either using the wrong tools or technique or both.
If you detail what your doing and with what materials and what tools, we can direct you.
Saying you tried everything and nothing works is not helpful information.
Ron
Old 12-19-2010, 12:47 PM   #6
That is a good point.
Old 12-19-2010, 05:52 PM   #7
Mastic is also a food source for mold. I wouldn't recommend it.
Best way (imo) is drill a hole in the concrete (rotary hammer preferably, hammer drill if desperate), then sink in a GRK Caliburn screw:
Hohn is offline   Reply With Quote
Old 12-19-2010, 06:54 PM   #8
Civil Engineer
Rewards Points: 4,860
Without knowing the depth of concrete, it is hard to recommend a technique. Options for fastening to concrete typically include Ramset 38 nails, Tapcon screws, lead shields with screws, plastic inserts with screws, or concrete screws. Each of these methods will work with proper technique, however the most effective method depends on the thickness and strength of the concrete.
Daniel Holzman is online now   Reply With Quote
Old 12-19-2010, 07:39 PM   #9
Oh. Another reason to not "glue" on concrete.
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 05:05 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 01:01 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
stamped concrete for kitchen floor??? 4just1don Flooring 8 12-03-2008 08:39 AM
