Concrete Steps And Stucco Cracked-Is This Structural Problem? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-14-2008, 12:55 AM   #16
ICF Construction
You mentioned a 7 year warranty, I assume you are in Ontario and covered under the ONHWP or Tarion?
Anyways, if that is true, you need to consider winter when making your decision.
Durock Allfacing in Woodbridge makes products that compliment the EIFS stucco that are meant for your porch and stairs, they have freeze thaw capabilties. Stone has worked well in winter but could be costly to complete. And for the tile, exterior tile can be tough in winter with so much freeze thaw, expansion and contraction of the soils, etc. Salt is another killer for these items, becareful in salting the ice in the winter.
Chris
Chris Johnson is offline   Reply With Quote
Old 04-14-2008, 12:57 AM   #17
ICF Construction
Oh, and I would repair the crack in the step with epoxy provided it is stable and not moving prior to a applying a new finished surface
Chris
Old 04-14-2008, 09:24 AM   #18
yummy mummy's Avatar
Rewards Points: 1,016
Yes, Chris, I am in Toronto, Ontario.
I will try the epoxy for the crack. As for the stucco crack, I have the product that they put on, so I will try to go over it on the stucco and hope it will cover it.
yummy mummy is offline   Reply With Quote
Stucco steps and explantion, please. iMisspell Building & Construction 2 06-13-2007 01:05 PM
