Concrete Step - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 03:43 PM   #1
Concrete step
wow cant believe i found this forum!
i have a single, large front concrete step. i have patio stones that have 2 levels down to the driveway, but the stones need to be redone. i want to remove the 2 levels, and pour a concrete lower step, and then run the patio stones to the driveway. the size of the lower step would be approximately, 7'8 wide, 2' deep, 6" high. my questions:
1. do i need a building inspector for this?
2. once you build the form, do i use fill (gravel, broken stones, cement blocks) or do i fill it all with concrete?
any help or suggestions is much appreciated!
Rick
Artimus20 is offline   Reply With Quote
Old 05-19-2010, 02:21 AM   #2
Rewards Points: 1,092
compact
No idea about the building inspector. If you are going to pour concrete, it is always recommended that the substrate be SOLID below it, or wider. That usually means removing dirt for several inches to a foot or more, filling in w/ gravel that will compact, and compacting in 4" lifts (fill 4", compact, fill more, etc). Whether you need 4" or 8" or 12" of compacted gravel, I don't know; if in doubt, go heavy and compact well. Check w/ your local building department. You may also need to compact beyond where the concrete will go, (wider) depending on how squishy your soil is. Once the substrate is suitable, 4" of concrete w/ mesh ought to be there for many moons. This may be overkill, but a sidewalk that tips in 5 years sucks. john
Old 05-19-2010, 05:59 AM   #3
Rewards Points: 4,454
go to an apron store & buy a book you'll be in a MUCH better position to ask questions,,, all conc work's the same,,, only thing that changes is project size,,, good luck !
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-23-2008 12:22 AM
Help fixing a concrete step smccull493 Building & Construction 5 07-10-2008 09:01 AM
concrete step repair & slate gemelli2 Building & Construction 5 10-03-2007 07:38 PM
