Concrete Slab - Sealing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 10:28 PM   #1
Rewards Points: 502
So I just had the barn floor slab poured today. It took 35 yards for 2800 sq ft.
I sprayed on a curing compound and now need to decide what I will do next month for sealing after I reach the 28 day cure mark.
What are the recommendations on sealing of indoor slabs?
On my last barn, I used Sherwin Williams Armorseal, but it didnt last more than a year before I had problems, even with acid etching. Additionally, it is expensive. For the 1700 sq ft I used it on, I spent over $500.
My goal is the ensure the floor lasts a rather long time and not have to worry about big stains from the tractor or other equipment that will leak either hydraulic oil, engine oil or diesel fuel.
Thanks,
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 08-08-2009, 05:05 AM   #2
Rewards Points: 4,642
we'd pick silicone siloxane OR eliteCrete's ' CSS ',,, CSS mtl cost's about $.15sf - current $ list,,, think you'll have to press/wsh 1st stuff but ck w/your distributor,,, no sealer lasts forever imn-s-hfo
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
