Concrete Slab Quote $2750 For An 18X31 Slab - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 08:25 AM   #16
Roofmaster
Rewards Points: 2,210
Four inches for a garage floor? A sidewalk maybe. I would not have anything less than 5 inches of compacted Quarry Process, #4 rebar, or at least No. 10 reinforcing wire, and 5-1/5" of 3400PSI Concrete for a garage floor.( 2 x 6 Forms)
As far as a spec goes the others are right. Asking for proposals from contractors without a proper specification is asking for trouble, because things might get left out in order to be low bidder.
In many cases the best way to do this type of thing is to negotiate with a contractor who has gotten good references, and listen to what he has to say.
You say fully prepared. To me, fully prepared means cleaned out leveled, Quarry process in place and vibra-plated, properly formed level, with vapor barrier in place.
What does it mean to you?
The Following User Says Thank You to jagans For This Useful Post:
oh'mike (02-04-2013)
Old 02-04-2013, 06:29 PM   #17
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would have to guess that the bids that are on the high end may include a footing. I would not do any slab without a rebar footing and rebar slab.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 08:55 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
