Concrete Slab Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 11:43 AM   #16
Rewards Points: 1,016
I get a wealth of info and help from my local building department. Plan reviews, preinspection consultations, etc. I like to do a preinspection where each step is discussed and what the inspector will be looking for, then at each inspection I review what is next.
Old 01-24-2010, 01:40 PM   #17
Remodeling Contractor
footings are 8-10 in your area. You will need help to do your own slab. Work must be done very quickly and finishing processes are critical to be done when the concrete is ready. You will need at least 4 people. This is not really a DIY project.
Old 01-25-2010, 12:09 AM   #18
Concrete & Masonry
Rewards Points: 470
Indeed go to your local buildign dept. to see if they have specs. A cross section from them could answer a ton of your questions.
And "Fibermesh" does not replace structural rebar, regardless of what anything you read says.
I would surely go the route of a grade beam/turned down slab/thickened edge slab for a detatched shed regardless of the frost line. The existing grade & outside dimensions could possibly change that opinion though.
jomama45 is offline   Reply With Quote
Old 01-25-2010, 05:58 AM   #19
Rewards Points: 4,454
slab-on-grade w/crush'd stone base's fine here in atlanta for your bldg's purpose,,, no fiber, wire mesh, or rebar, either,,, if the shed's larger'n 8' x 10', i'll change recommendations, tho
Old 01-25-2010, 07:20 AM   #20
Lost..
Rewards Points: 336
Building is 12x16, 6/12 shingle roof. Light wood frame construction. nothing heavy on the slab itself.
I'm going to go talk to the building dept today. I'm going to run some of these questions by them, surely they can point me in the right direction.
J S Machine is offline   Reply With Quote
Old 01-27-2010, 04:23 PM   #21
Lost..
Rewards Points: 336
Ok, I have talked with the building dept some more. I went by there the other day on the way home home from work, but nobody was still there that I needed to talk with. I just called a little bit ago and talked to someone who helped me a little bit.
They said it would need 12x12 footings. I asked if it would need rebar if I use fibermesh concrete, and they said it would need rebar in the footings but none in the actual slab. I am off of work friday, so I am going to try and make an appointment to go in and sit down to talk to them.
I didn't realize that this was going to be such an involved project, so I'm going to take it one step at a time. I'm going to concentrate on the slab first, and then worry about the frame after the slab is done and i'm certain everything is ok.
So for now, I just have a couple of questions. When they say 12" x 12" footings, does that mean 12x12 with 4" of the slab on top to be 16" in height, or 12x12 with the slab included? Here is an illustration.
I checked out Willie T's illiustration on batter boards in the other thread, but I was wondering if anyone has a complete set of instructions or a link to some that show the process start to finish. I want to know where to get started, and do this right fom the get-go.
Old 01-27-2010, 04:46 PM   #22
Old School
Willie T's Avatar
Is that the way the Building Department showed you to make your 'haunch' footers? It is not the correct way. That inside dirt wall needs to be sloped back at 45 degrees to 'ease' into the slab. The sharp turn shown will soon create a crack line.
Batter Boards: http://www.mydiscounttools.com/estor...anuals/ch4.pdf
This is a little complicated, and I personally think the separate board setups, three feet back, are better. But this will get you there.
Willie T
Old 01-27-2010, 04:55 PM   #23
Lost..
Rewards Points: 336
Give me a break man. I'm a toolmaker, not a General contractor. If you need a die built or a precision vise, I can do that. I'm kinda in the dark here though when it comes to this code stuff.
I don't know the correct way. I'm sure they do, but I haven't had the pleasure of actually getting to talk to them that much. I work 12 hours a day, so getting down there before I get off is kind of not an option. When I went the ther day the one guy I needed to talk to was gone already. I left work early to get there before they shut down but I missed him. Getting information over the phone isn't gonna happen, I've already tried that. Needless to say, it's getting frustrating. I'll have friday off of work, so I will make an appointment to talk with the guy. He knows his stuff, he's just hard to catch.
I'm simply posting here trying to get some pointers on where to get started. If it isn't obvious, my illustrations show my ignorance. I am willing to learn though in order to do it correctly.
Thanks for the link. It looks pretty informative. I'll have to go and pick up some 2x4's to cut up and use as stakes and some string.
Old 01-27-2010, 05:04 PM   #24
Old School
Willie T's Avatar
Sorry. I thought they gave you drawings like that.
Concrete, just like your metal toolings, does not react well to sharp corners. Think of how you bevel and ease corners and drilled holes to eliminate any sharp, 90 degree corners. Same thing, only with concrete you make the bevels much longer.
Willie T
Old 01-27-2010, 05:08 PM   #25
Lost..
Rewards Points: 336
Maybe when I visit Friday, they will have some drawings there at the office or some pictures that will more acurately explain what they require. I'll be sure to ask.
In the mean time I have a feeling I may be needing a plumb bob. Haven't seen one in years since my dad was still alive, but I think I can spin one out on the lathe. I guess all it really needs to be is a pretty heavy metal piece with a point turned on it and a loop on the top to attach the string to.
Old 01-27-2010, 05:14 PM   #26
Old School
Willie T's Avatar
I've actually used a big nut on a string before.
Willie T
Old 01-27-2010, 05:32 PM   #27
me to the nut was my brother
Old 01-27-2010, 06:22 PM   #28
Concrete & Masonry
Rewards Points: 470
Check out this thread for more info:
Concrete Footings for a Detached Garage???
Posts #2, 4 & 8 all have good images, except in post #8, your bottom dimension would be 12" instead of 18". If you do some more searching, I know there have been some other good images of grade beam slabs on the last year or so.
Old 01-27-2010, 07:17 PM   #29
Its right under my username folks..
36092
I don't know many people who know zip codes, or that will look them up
I know I don't look up zip codes
Might want to add your location to your profile
Its the 1st question a lot of people ask before they reply
Old 01-27-2010, 07:51 PM   #30
Old School
Willie T's Avatar
Scuba Dave is absolutely right.
7 4 17 4 - 8 18 - 22 7 24 - 8 19 - 8 18 - 1 4 19 19 4 17 - 19 14 - 18 15 4 11 1 - 18 14 12 4 19 7 8 13 6 -
14 20 19 - 8 13 - 15 11 0 8 13 - 11 4 19 19 4 17 18.
Translation:
(Here is why it is better to spell something out in plain letters.)
Willie T
Concrete slab question mudpaws Flooring 2 10-18-2009 08:38 AM
concrete grade/bond beams under slab? jklingel Building & Construction 7 12-22-2008 01:43 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
