-   -   concrete slab for new home in coloma, wi (http://www.diychatroom.com/f19/concrete-slab-new-home-coloma-wi-81503/)
jody&damion 09-15-2010 02:31 PM
how thick should the slab be, should it be reinforced with mesh or rebar?
steveel 09-15-2010 03:08 PM
It should be whatever your code officer and architect or engineer say, and if you haven't already heard about "frost proofed shallow foundations" suggest you google that phrase and read up on how to save a lot of concrete
Gary in WA 09-15-2010 03:55 PM
And use a vapor barrier under the slab on the crushed stone capillary break: http://www.nrmca.org/aboutconcrete/cips/29p.pdf
Air seal the slab: http://www.100khouse.com/2009/06/24/...b-air-sealing/
No loose sand layer: http://www.buildingscience.com/docum...sture-problems
Check your heating degree days for required rigid foam board at perimeter:
http://www.energycodes.gov/support/slab_faq.stm
Soil conditions and the plans will dictate required use of steel, as mentioned.
Welcome to the forum!!
Gary
stadry 09-16-2010 03:46 AM
why do you want to know ? ? ? monopour/unipour foundations weren't normally a conversation that couples had in MY younger days :no:
