Concrete Slab Moisture Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 08:15 AM   #1
concrete slab moisture barrier
does the vapor barrier for a concrete slab go into the trenches and up the outside of the perimeter trench
joe v is offline   Reply With Quote
Old 01-18-2011, 05:08 PM   #2
You can certainly do it this way. I just asked my building inspector and was told I could. I believe it will further minimize the amount of moisture absorbed by the slab.
rich&poor is offline   Reply With Quote
Old 01-18-2011, 05:28 PM   #3
Rewards Points: 4,656
yes, you can - no, we wouldn't - neither would most pro's nor would an arch/engineer spec it to be done as you post
Old 01-22-2011, 12:56 AM   #4
Rewards Points: 1,092
You mean you want to install a moat around your place? Do you think that's a good idea? I'm w/ itsreally on this one, unless there is absolutely no way for the water in the ditch to get back to the house, which it does not sound like from what you said. (ie, I see the water getting from the ditch to the house). I use french drains for gutters, but they are 3' from the house, and their own, separate ditch.
how important is it for moisture barrier to cover sides of floating floor? conradA Flooring 2 04-29-2010 10:13 AM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 11:51 AM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
lifting up concrete slab ctudan Building & Construction 1 10-28-2008 02:44 PM
Mold prevention over concrete slab leob Flooring 4 05-22-2008 10:13 AM
