Concrete Slab Load - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 02:04 PM   #1
Rewards Points: 212
concrete slab load
Hi I am thinking of changing my roofline. There is a room added onto my house sitting on a slab. The slab is 6 inches thick but does not have a footer.
It is 6 inches of concrete sitting on top of the soil. I live in nashville tn so the winters are cold but not extreem like the northeast.
Right now the roof is a 3:12 but I am looking to change it to an 8:12. So the slab will be bearing more load on the edge. This roof will be sitting atop a 2x4 wall.
I am wondering if the slab will start breaking on the edge or if I have nothing to worry about because after all... it is conctete and concrete is strong. Here are some pics of what I got right now
If you could picture the roof going from the front all the way to the back and do away with the compound pitch
concrete slab load-roof-008.jpg   concrete slab load-roof-010.jpg   concrete slab load-roof-011.jpg
bluebird5 is offline   Reply With Quote
Old 04-16-2011, 12:53 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
You really need to have footings and a good overall design before starting. Talk to an Architect or if too expensive a good designer in you area. From the description of work it sounds like an awful lot of work for a DIY project.
Andy.
AndyGump is offline   Reply With Quote
Old 04-16-2011, 05:18 AM   #3
Rewards Points: 4,448
IN n'ville or just outside ? 1st ck w/bldg permit/const office to see what you need,,, i'm in ga & some parts down here don't care while others ***** & moan if you lop off a tree limb ( guess where my bride, nagzilla, wants to live ) w/o a permit,,, you won't be adding a lot of static weight.
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 10:55 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 11:57 AM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
