Concrete Slab Layering & More - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2007, 09:32 PM   #1
Rewards Points: 1,062
concrete slab layering & more
i am lowering my basement floor. the existing concrete slab is only barely 2 in thick but i will make the new 3 in.
Q1: how much gravel should i use under a 3 in concrete slab ? i was thinking 1 in.
Q2: a matter that puzzles me is setting the frame so that is absolutely 100% level. i will be doing it in stripes so the frame will actually be only one-dimensional (from one wall to the other, i.e. not a box). should i first set the stakes and then nail the 1x4 to it or make the structure first and set it in all together? the former sound easier to do and make it flush but i am afraid of screwing up the stake position while nailing the board to it.
Q3: should i get a 48 in level for this or is a 24 in one good enough ?
- a
Old 06-13-2007, 09:48 PM   #2
Commercial Contractor
Concrete forms
Q1 the deeper the gravel the better. All concrete will crack given time that is guaranteed, but the better gravel, and proper tamping (use a tamping machine) will prevent it from cracking to often
Q2 I would use 2 x 4 minimum, you should have at least 3 and a half inches of concrete. use the metal form stakes every 4 feet to prevent bowing of the concrete. Spread a thin layer of Kerosene on the 2 x 4's before placing to prevent the concrete from sticking. Once you've poured the concrete tap the outside of the boards along the framing to settle the concrete to keep it from creating air pockets.
Q3 I would definetely use a 4 foot level and double check it with your 2 foot level to make sure that it is not bent by placing it on top of it. Both bubbles should read the exact same. If not buy a descent level (Stabila make preferred)
The professional is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
