Concrete Slab With Hot Water Heat- Moving Walls - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 08:48 PM   #16
Concrete & Masonry
Rewards Points: 636
I'm not sure if thermal imaging would cold be "fine tuned" enough to show an actual tube thru 3"+ of concrete. They're also not the most readily available tool either. I have a "Raytek" infared thermemeter, & I can't tell where any one tube may be in the floor. If your worried about drilling a hole or two 1" into the floor, you should try cutting a few hundred feet of control joints in a floor!
jomama45 is offline   Reply With Quote
Old 04-06-2009, 02:08 PM   #17
Alomost done
For those who care:
skizsam is offline   Reply With Quote
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 03:07 PM
