Old 03-02-2005, 07:07 PM   #1
Concrete Slab Help
I am starting an addition on our lake cabin. I need some advice. The addition is going to be approximately 19X28. My problem is i am not sure i can do a slab foundation. The reason is this. Corners A and B will be attached to the existin slab. Corners C and D will be the 28 ft ends. During this 28 ft, there is a decline in elevation. On C corner, it drops to 16"...On D corner it drops down to 30". The books i have read say that you can only fill up to 24" with sand or sandy loam type dirt. Less than that with gravel. The grade is iron ore. Very solid, but i am afraid of the 30" drop. My question is how do you handle this? Any help will be appreciated.
Craig
craigNeasttx is offline   Reply With Quote
Old 03-08-2005, 06:37 AM   #2
Concrete Slab Help
take slab down lowest point on site.build foundation on top to d.p.c.
jonneybbob is offline   Reply With Quote
Old 03-08-2005, 06:45 AM   #3
Smile
Concrete Slab Help
or buil..d standard foundation of brick and block and infill with hardcore.and slab on top d.p.c. level.
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
