Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 07:07 PM   #1
Concrete Slab
Hi, We are having a house built and the concrete slab was poured. There are a couple of spots that don't look right to me - you can see gravel in a couple of spots around the perimiter of the slab (as part of the slab). Also, there is a floor outlet that in in the slab and instead of pouring the slab with the outlet tube in it they poured the slab and then cut out a section to put the tube and then patched it over. Is this correct or should I be worried? Thanks for your opinions!
http://s1102.photobucket.com/albums/...ent=slab_7.jpg
http://s1102.photobucket.com/albums/...ent=slab_1.jpg
http://s1102.photobucket.com/albums/...ent=slab_2.jpg
http://s1102.photobucket.com/albums/...ent=slab_4.jpg
dgaz is offline   Reply With Quote
Old 11-12-2010, 10:21 PM   #2
jlhaslip's Avatar
Rewards Points: 396
Nothing there would scare me away.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 11-13-2010, 01:17 AM   #3
Rewards Points: 956
thats awesome you are building it from scratch. where is this
federer is offline   Reply With Quote
Old 11-13-2010, 12:04 PM   #4
jlhaslip - thanks for the reply. I am hoping all is good with the slab.
federer - we are in phoenix arizona.
Thanks!
Old 11-14-2010, 08:37 AM   #5
Concrete & Masonry
Rewards Points: 470
In pic #1, I guess they forgot a floor outlet, what else could they do in the situation. The only thing that would concern me would be that it appears that the slab is post tensioned from pic #3. Not sure if the trench compromised the post tensioning or not.
Pic 2 Standard honeycombing at the slab edge, not the end of the world IMO.
Pic 3 Gravel buildup at form edge should have been cleaned up before pour, but doesn't appear to be a serious issue again.
Pic 4 What the slab should look like, no issues there.
jomama45 is offline   Reply With Quote
Old 11-14-2010, 11:50 AM   #6
jomama45 - Thanks - you made me feel much better.
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 10:55 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 11:57 AM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
