Concrete Slab ?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 03:41 PM   #1
Concrete Slab ??
Will be tearing off old deck that is built over a concrete septic tank.I would like to replace the deck with a stamped concrete patio.My builder has not absolutely confirmed this can be done.Can a slab be poured over a septic tank?Thanks
workalot is offline   Reply With Quote
Old 08-16-2009, 04:20 PM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
Not in my neck of the woods. Best person to call is your township health department. They typically have jurisdiction over septic systems. In my area they let you do pretty much anything over the tank (pavers, landscaping) except construct permanent features on it or within a certain number of feet of it. But your town's health department should be consulted for the local rules in your area. That's a 1 minute phone call.
I'm actually kind of shocked they let you construct a deck over it in the first place. They don't allow that where I am.
Aggie67 is offline   Reply With Quote
Old 08-16-2009, 04:25 PM   #3
Drywall contractor
Rewards Points: 1,070
Agreed, whether your contractor can or cannot answer the question, the building dept. can and they're the ones you have to satisfy. Even if you're attempting to get in "under the radar" without a permit, it could come back to haunt you when you get ready to sell. You may be able to do it if you install an access for the purpose of pumping it out when necessary. I kind of doubt it though....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-16-2009, 04:45 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Personally even if you can I would not. What if it breaks and starts leaking or something and needs to be repaired? I would maybe put a wood deck instead, and maybe even construct in a way so it's easy to remove the deck and put it back, in case it ever needs to be done.
Old 08-16-2009, 11:11 PM   #5
Concrete & Masonry
Rewards Points: 526
I've done it several times, one was even a driveway over a septic tank. BUT, as noted above, you really should consult with the local agency (county ext., enviro. health dept. here) to see if it's allowed. For the driveway, it was a new system & I worked closely with the septic contractor. He ordered a heavier tank for this job & we constructed the slab to act as a bridge, of sorts, to spread all the weight. If the tank has risers & cover that need to be accessed, the slab CANNOT rest on the risers or it will eventually destroy the tank.
jomama45 is online now   Reply With Quote
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 03:32 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
