Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2007, 08:47 PM   #1
Concrete Slab
What is the average cost of a poured concrete slab 36x24? I'm in Virginia. I'm planning the build of my Garage and I'm trying to do it for the least amount of money....no cutting corners.....just don't want to pay 40K for something I could probably get 10 guys over to the house with some plans and build it in a couple of weeks...for beer and BBQ oh an the game on my home theater system..LOL!!
Almost forgot....
Is it cheaper to build your own trusses or buy already built?
Smitty is offline   Reply With Quote
Old 09-08-2007, 07:30 PM   #2
DeeTee's Avatar
Cool
Slabs and Trusses-Not for the faint of heart
It's very hard to come up with a cost for a project unless you are "in the know" of the local area, the plans, the specifications, the conditions at the site, whether it's the whole job including prep or just the concrete portion. That being said I know what you're getting at- you don't have any idea what this would cost so you want a starting point. $3800, 5" of concrete, 3000 psi, slab on grade, slab base, fine grading, forms, vapor barrier, wire mesh, finishing and curing.
I would always opt for the pre-built trusses. The things are engineered. Unless you're an engineer you probably won't be able to factor in not just the roof loads but the prevailing wind loads, the proper sized members so their own weight doesn't become a factor and the proper fasteners that aren't going to allow unstable deflection, etc, etc. And to be honest I think a factory can do it quicker and cheaper than a few guys with some saw horses, skill saws, and a couple cases of beer (although it probably wouldn't be as much fun). That being said there will undoubtedly be those who will insist a DIY truss is a piece of cake. Peace of mind is what it's all about.
__________________________________________________ ___________
News Views Commentary Tips Downloads at the Construction Informer
DeeTee is offline   Reply With Quote
Old 09-08-2007, 09:09 PM   #3
Hand framing is quicker if you have not worked with trusses before, and it is more satisfying.
Out of the last five jobs I have had two with inconsistent heel heights. Inconsistent heel heights causes the roof edge to go wildly up and down.
This caused me hours of screwing around to fix the trusses. Both times I got compensated by the truss manufacturers but unless you have a relationship with them they will probably tell you your on your own.
For cutting rafters, make one pattern and trace that pattern onto all the others.
You may need to educate yourself on how to cut rafters with a birds mouth, and there is some math involved. So if this is not a strong suit maybe trusses would be better for you.
jiggyjack is offline   Reply With Quote
Old 09-08-2007, 09:32 PM   #4
I think I will go with already made trusses....but if the plans I'm buying have the design already in them then I guess the engineering part is done. I'm buying the plans for this garage....this is the link to it.
http://www.justgarageplans.com/plan.php?planID=173
Hopefully after figuring out the concrete then the trusses I can move on to total amount of material needed to make this happen. A contractor here wants 35k to build it....I believe I can build it myself for less.....but isn't that what this is all about...LOL!!
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
