Concrete Shoring? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-05-2005, 04:33 PM   #1
concrete shoring?
I have an exterior load bearing wall that does NOT have a footer it is only setting on a 4" pad. I am renovating and the city says that it needs to have underpinnings. What does this mean?
maintenance is offline   Reply With Quote
Old 08-12-2005, 10:04 AM   #2
There are 2 possibilities. Most likely what it means is that you need to find a way to support the wall while you excavate underneath it, then pour a concrete footer. However, underpinning usually refers to driving deep piles to support a foundation. I don't know how they would expect you to do that, so most likely they want you to do the former.
alexschmidt is offline   Reply With Quote
Old 08-15-2005, 11:44 AM   #3
Rewards Points: 150
underpinning
pipeguy is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
