Concrete Shed Turned Office - Leak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 07:22 AM   #1
Concrete shed turned office - leak
Hi there! So glad I found this site. I have a leak problem...can't imagine where the water is getting in, but we saw it on the floor of a concrete block shed set that we turned into an office. The roof is brand new so we are pretty sure it's not getting in that way - in fact, we thought it might be coming in along the bottom of the wall. So we put silicone in a 1/2 inch space that was there along the bottom of the wall and then more inside, under the baseboard. To no avail - after a week out of town (with the heater/air-conditioner off) we discovered thick mold growing all over the molding around the window on that same wall. Pulled off the baseboard and cut out some of the drywall at the bottom and found a small amount of mold. Any ideas how I can determine the origin of the leak? And then prevent water from getting in? I'm not sure who to go to or what to ask to find out. Any ideas would be greatly appreciated!!
harpcomm is offline   Reply With Quote
Old 02-25-2011, 08:31 AM   #2
Stay-at-home GC
Pictures of inside and outside. Close-ups but more importantly perspective views for overall eval.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-25-2011, 08:41 AM   #3
Rewards Points: 5,336
You might have multiple issues. The window might be leaking and running down the wall and there might be a floor leak.
As stated, post pictures.
Check exterior drainage and gutters(for clogs).
Ron
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 03:49 PM
Stained concrete floor showing water leak Rox Plumbing 0 09-27-2010 03:33 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
