Concrete Seam Seal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 08:46 PM   #1
Rewards Points: 1,088
Concrete Seam Seal
What type of caulk/seal is used to fill seams in driveway expansion joints and other concrete joints.
It doesn't look like the self leveling caulk, and appears more like an elastomer that bonds well, can be formed, and holds its shape well, unlike a self leveling type of caulk.
handy man88 is offline   Reply With Quote
Old 03-05-2009, 09:00 PM   #2
Sikadur?
jerryh3 is offline   Reply With Quote
Old 03-05-2009, 09:29 PM   #3
Originally Posted by jerryh3 View Post
Sikadur?
Does Home Depot carry this?
Old 03-05-2009, 10:04 PM   #4
I know they carry Sikaflex, but I'm not sure if they carry the sikadur. Is there a reason you don't want to use the self leveling kind?
Old 03-05-2009, 10:24 PM   #5
If you have a seam/crack that's deep, then you may go through an entire tube of self leveling caulk before it fills the seam/crack. Also, self leveling caulk doesn't work well on the rise seam of concrete walk up stairs, and can be messy.
Old 03-06-2009, 04:36 AM   #6
Maybe backer rod and the sikaflex for the horizontal seams? I guess you will need something a little stiffer for the vertical seams.
Old 03-06-2009, 06:36 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Use a urethane based caulk for masonry. Masonry absorbs moisture which will break the bond on most other types of caulk. For deep joints, use a non absorbing or closed cell foam backer rod. Then fill the joint on top of the rod. The caulk joint should not be deeper than the width. For wide joints thinner is better.
http://www.masterwall.com/files/mw14...lantdesign.pdf
Old 03-06-2009, 07:45 AM   #8
we'd pick polyurethane, polysulfide, OR 100% silicone,,, the depth:width ratio should be on the container - if not, ck the website,,, silicone's not to be installed thicker'n 3/8",,, either closed or open cell backer rod should be used to form the sealant btm,,, you never want 3-sided adhesion.
clean the jnt walls 1st & be sure they're dry when sealing.
yesitsconcrete is offline   Reply With Quote
Old 03-06-2009, 08:07 AM   #9
Remodeling Contractor
What do you have against the self leveling type. At least you do not have to tool it. I use Sonneborn's SL-1 one part elastomeric self leveling polyurethane sealant. And as posted you need a backer rod under the sealant to only bond to the two sides of the joint.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How do I seal the seam in rubber flex piece? faithfulfrank HVAC 3 06-26-2008 11:13 PM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 07:48 AM
seal a concrete water tank timbo General DIY Discussions 16 01-18-2007 04:08 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
