Concrete Sealers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 02:58 PM   #1
Rewards Points: 12
Concrete Sealers
Can anyone recommend a penetrating concrete sealer for a subfloor (ground level)? I am trying to solve a water intrusion issue with water wicking under recently installed French Doors (see my post "Leaking French Doors" for more of the story) to the inside. I am hoping that this might be the answer.
I would also like to use something as a general sealer to seal the entire slab as an extra precaution in preparation for a wood floor intallation.
TIA
pianodude is offline   Reply With Quote
Old 09-07-2009, 03:34 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I think of concrete sealers as being like a raincoat over the floor to keep the concrete dry, but if the moisture is coming up through the concrete, I don't think the 'Sealer' will work, especially if there is any kind of hydrostatic pressure.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-07-2009, 03:39 PM   #3
Remodeling Contractor
concrete sealer is used to protect the surface of the concrete. To address your problem apply several coats of dryloc. If the concrete has paint or sealer already on it, then these will need to be removed first. But as mentioned hydrostatic pressure will not be stopped. For this you need to drain the water away from the bottom of the concrete.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
