Concrete Screw Up - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2008, 08:59 AM   #1
Concrete screw up
My wife and I were trying to add another 2 inches to an existing concrete slab. We got a late start early yesterday evening as we grossly underestimated the time it would take for mixing etc. and we finished the mixing and pouring around 1 am last night. We did not have a chance to strike off smooth it out. This morning it looks really bad... Aggregate at the surface, and very uneven. Now the concrete is partial set, is there anything we can do to fix it at this point?
Any suggestions are greatly appreciated.
riotact is offline   Reply With Quote
Old 07-06-2008, 09:20 AM   #2
Registered User
Termite's Avatar
Too late to modify the stuff you poured last night. The hydration process has already taken hold, and although the concrete is still "green", messing with it will do more damage than good, and could compromise its integrity, looks aside.
My suggestion would be to look into self-leveling (flowable) concrete to cap the bad job. Contact a local batch plant.
Old 07-06-2008, 09:31 AM   #3
Thanks. Would a concrete resurfacer be the same thing? And if so can it be done immediately or will I have to wait for it to fully cure?
Old 07-06-2008, 01:20 PM   #4
Registered User
Termite's Avatar
Concrete resurfacer is the bag version of what I'm talking about. I think it is super-expensive in bags.
You can overlay the ugly slab as soon as you want. Concrete will continue to harden for a long time, but develops the bulk of its strength in 4 weeks. Covering it with more concrete won't impede the curing process. You're safe to walk on it the day after pouring.
Old 07-06-2008, 01:58 PM   #5
General Contractor
joasis's Avatar
What kind of prep did you do to the existing slab before you poured the 2 inches? Bonding agent? Scarifier used? There is very little strength in a 2 inch "cap" on concrete, especially if it doesn't bond with the existing slab. If the area isn't that large, break it up...or you may wait a few days and it will crack anyway . Not being negative here, just informative. Was there a reason you wanted to raise the slab 2 inches?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 07-06-2008, 01:59 PM   #6
How big of an area are you talking about. Now you can bust it out and redo if you want. It will break easy if still green.
BillyD is offline   Reply With Quote
Old 07-06-2008, 03:09 PM   #7
This is riotact's wife. We are in the process of ripping it out right now.
Before pouring the new concrete we power washed the old concrete stoop and applied Weldbond just before the pour.
I think there were several factors at play here. One being that we had to use two different types of concrete. The first was fiber reinforced Quikrete, which actually turned out very well, however we ran out and needed to get more. Unfortunatey Home Depot in Canada does not sell the fiber re-inforced so we ended up using the Quikrete 5000.
I even noticed last night that the Quikrete 5000 seemed to have more aggregate in it.
We are now back to pondering what to do with the stoop. We had a 1 1/2 inch gab under the door sill that went back to the wood joist because bricks had rotted away. The flagstone on the stoop was all loose and falling off.
So now to decide where to go from there. We thought we'd save ourselves some money by doing the concrete...... now we just wasted $150.
Old 07-06-2008, 06:29 PM   #8
Not wasted you learned a lot. Now plan to do it over and learn from this trial run. Now you know how much concrete you need and how much time. You can do it. How did bricks rot away?
Old 07-06-2008, 06:34 PM   #9
not having seen it i would have suggested fixing the flagstone... which is usually much more rich looking that cement slab. do you still have enough nice flagstone? some S type cement is all you need to place these down again.
jupiter2000 is offline   Reply With Quote
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
