Concrete Roof - Support Structure For Wet Mud - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 11:21 AM   #1
Concrete roof - support structure for wet mud
We are building (with contractor) a sub-grade garage with concrete roof to allow parking on top.
Right now we have completed walls and 4 I beams in place. The structure is 28' x 40', the 27' I beams sit at 8' centers. We need to frame up a floor in between the I beams / walls that can support 6" of wet mud.
By my calculations we can run 2x12x8' at 16 oc. The ends of the 2x will rest on the lower beam flanges and on a 4x6 beam on the wall ends supported by 4x4 @ 2' oc. Then 3/4" cdx for the deck.
Myself and the contractor rejected the engineers original plan due to extreme cost. The structure, once cured, meets the engineering requirement. I want to save the labor/ material mark up and build the floor structure myself. The floor will need to support 60 lbs/sqft (dead load) plus the workers walking around during pouring.
Deflection would need to be at a minimum. Whatever i come up with I'll send to the engineer, he wants to see it before we pour. Just looking for any thoughts or opinions. Thanks - Tom
tvanharp is offline   Reply With Quote
Old 08-12-2012, 11:42 AM   #2
robertcdf's Avatar
What are you going to do to waterproof that wood? Concrete is NOT waterproof, water will leach through to that wood (I've seen it on concrete decks, rotting wood holding up concrete... not good)
Stick with steel framework and steel floor decking.
robertcdf is offline   Reply With Quote
Old 08-13-2012, 12:24 AM   #3
The wood will be removed it just needs to support the concrete till it cures. The 4 14" I beams and outer walls will be supporting the load.
The concrete will be stained and sealed.
Old 08-13-2012, 09:15 AM   #4
concretemasonry's Avatar
Rewards Points: 2,578
tvanharp -
Make sure you have enough steel (small size and close together) to minimize the size of the cracking. All the sealing in the world will do little good if there are cracks. You will obviously have shrinkage cracks, but they must be minimized in spacing and size.
It is more than a structural problem and parking structures are unique creatures.
Dick
concretemasonry is online now   Reply With Quote
Old 08-13-2012, 09:23 AM   #5
robertcdf's Avatar
So you're spanning 8' with concrete? I know it's doable but at what cost? Are you sure some good steel floor decking won't be less (and more watertight) in the long run?
Old 08-13-2012, 10:08 AM   #6
I dont know, can i park cars on it? Are you refering to pan decking? Would you pour concrete on top of the steel?
Old 08-13-2012, 10:12 AM   #7
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
There are shrinkage reducing additives you can specify when ordering your concrete. We used one called Eclipse on a high school job we did about two years ago. Getting the air entrainment to behave itself was a challenge, but once we got it dialed in, it worked pretty good.
Mort is offline   Reply With Quote
Old 08-13-2012, 10:18 AM   #8
Have you considered renting the scaffolding they use on commercial jobs to supper your pour?
Most garage structures/concrete building use the scaffold/plywood form method.
Have you looked into flexicore?
Doorman54 is offline   Reply With Quote
Old 08-13-2012, 10:27 AM   #9
We will be spanning 8' with 6" thick concrete not sure what the rebar specs are but i have a signed and approved engineering plan that cost me $2000. I do know on the plan it calls for cuts along the beam centers so it cracks on the beams. Also my contractor has done these types of structures before.
Old 08-13-2012, 10:30 AM   #10
Not sure what flexicore is but i will look into the scaffold thing that may save money over all that dimensional lumber and provide better support.
Ill also investigate flexicore
Old 08-13-2012, 10:33 AM   #11
Flexicore is a precast concrete panel. I'm gonna guess 4-6' wide and maybe 50' would be its max length. They bring it in on a semi, set them with a crane, seal the joints and they are done!
Old 08-13-2012, 10:45 AM   #12
Yes i did look into that. I used to live in wi. Out there it was called spancrete, i did find a company in spokane wa, that sold the same precast / pre-tensioned panels but the cost was about $11,000 just for the panels, and we're not sure if they could even get the trucks to our location. Not to mention the delivery and install cost, we are pretty remote with a half mile dirt road that winds up a mountain.
Old 08-13-2012, 11:30 AM   #13
Flexicore panels are very often 24" wide and allow much smaller cranes and allow faster, cheaper and easier construction/placement on smaller jobs than the wider planks that are 40", 48" or 86" wide. Because Flexicore is a wet cast prestressed plank it has a much smoother bottom surface the the wider planks like Spancrete, SpanDeck and the others that use a much coarser, drier low slump concrete.
All precast planks will have to have a topping (2" or so) to provide a smooth top surface. The planks do eliminate any need for scaffolding, forming and shoring.
Dick
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
6x6 Roof overhang support posts Markland Building & Construction 0 04-27-2011 09:31 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Support columns for second story roof deck MugsynSax Building & Construction 3 10-05-2010 10:27 AM
Fixing a leaking concrete roof akankoh Roofing/Siding 7 04-28-2010 11:16 AM
