Concrete Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 10:40 AM   #1
Unhappy
Concrete Repair
Hi,
Anybody here to Help on solving this concrete problems taken Place in my new house under construction work had stopped due to madness of my Mad Friend ( Civil Engineer ) and getting repair by ME as DIY Here is the detailed Pictures Link http://picasaweb.google.com/lh/photo...eat=directlink
http://picasaweb.google.com/11671463...eat=directlink
meetranjith is offline   Reply With Quote
Old 11-01-2010, 12:19 PM   #2
Rewards Points: 5,336
It would help if you explained what we were looking at and paid a little less attention to the graphics.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
meetranjith (11-02-2010)
Old 11-01-2010, 02:56 PM   #3
Rewards Points: 4,732
wtf is that ? ? ?
stadry is online now   Reply With Quote
The Following User Says Thank You to stadry For This Useful Post:
Old 11-01-2010, 08:29 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Originally Posted by itsreallyconc View Post
wtf is that ? ? ?
Donno,but I'm bettin' it ain't in North America...
Haiti maybe,..?? Naw,... no blue tarps...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 11-01-2010, 10:29 PM   #5
Rewards Points: 968
the large font doesnt help either.......
federer is offline   Reply With Quote
The Following User Says Thank You to federer For This Useful Post:
Old 11-02-2010, 02:58 PM   #6
SteelToes's Avatar
Rewards Points: 150
Concrete
Hey meetranjith my name is George and I work for a Chicago area Home Depot. I have worked before in Europe implementing some of the techniques that were attempted on this building. First of I can tell that most of this concrete has been mixed on the spot and not using correct ratio of Portland cement and aggregates. Secondly the "form" that was built to support the ceiling was built and supported incorrectly with a wrong grade of plywood; they have used construction grade boards and "cdx" plywood that is not suitable for this kind of application. In addition of using a wrong plywood (they where suppose to use a 21mm plywood with smooth waterproof backing), they have also positioned wrong size rebar and mesh through the building, concrete was poured in sections and not being vibrated etc. To conclude I would strongly recommend getting a structural engineer to inspect this building, I can see some safety issues here, especially with a soffit (first picture) that is built around this house and not being tied with a ceiling slab.
SteelToes is offline   Reply With Quote
The Following User Says Thank You to SteelToes For This Useful Post:
meetranjith (11-03-2010)
Old 11-02-2010, 04:12 PM   #7
leave it to an apron store guy to discover all the defects think those patterns are from form liners ? seriously, where IS/HAS this taken place ? from the rust on the exposed steel, its not new const.
forming materials often don't meet us codes but there're lots of buildings around the world still standing after 500yrs or more,,, i think your ' mad engineer ' is actually your best friend even if he isn't a structural guy.
Old 11-03-2010, 02:23 AM   #8
Excellent Diagnosing But the Fact is In our Area the contractors are using Coconut Tree woods only instead of Plywood. Whatever it may be happened shall you suggest me an Technical idea to solve this Problem ? Sorry for my poor English Please Forgive me.
Old 11-03-2010, 02:35 AM   #9
Here You can see the current status of the Building http://picasaweb.google.com/11671463...eat=directlink It's new One.
Old 11-03-2010, 08:54 AM   #10
Rewards Points: 1,644
I'm not sure what the "problem" is; is it the rebar showing or the exposed aggregate?
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
meetranjith (11-04-2010)
Old 11-03-2010, 09:26 AM   #11
Rewards Points: 1,232
There only repair possible is to fill the voids. In the US I would recommend a premixed patching mortar, but I am doubtful that you have access to it where ever you are, so you will have to make it yourself.
1 part portland cement
3 parts sand (<1/8" aggregate)
Mix it using either an acrylic or latex emulsion as a bonding agent. Add the bonding agent to the mix water at 10-25% of the mix water.
It should be somewhat stiff, but not crumbly, about the consistency of peanut butter.
Trowel it on in small amounts completely filling all voids.
When finished, use the same mix, but make it thinner, about like pancake batter, and rub the entire concrete surface with the mix using a sponge float.
Good Luck!
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 11-04-2010, 10:02 AM   #12
Rewards Points: 198
i don't know about you guys but i'd love this as a fort in my back yard
vote4Pedro is offline   Reply With Quote
The Following User Says Thank You to vote4Pedro For This Useful Post:
meetranjith (11-05-2010)
Tags
bricks , cement , concrete , repair , walls
concrete repair sunnystorm Building & Construction 1 10-31-2010 10:24 AM
Plumbing line in exterior concrete for pool Hawk334 Plumbing 4 07-04-2009 10:13 PM
Best way to repair concrete retaining walls? ohman Landscaping & Lawn Care 2 06-25-2009 11:45 AM
Concrete chip repair prior to ceramic floor tile? libbybuddy Flooring 2 06-10-2009 04:54 PM
concrete step repair & slate gemelli2 Building & Construction 5 10-03-2007 06:38 PM
