Concrete Relief Cuts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 03:21 AM   #1
Concrete relief cuts?
On a 16x20 foot 6 inch thick pad with remesh in it, how deep do I need to make the relief cuts?
Shellsburg is offline   Reply With Quote
Old 06-09-2011, 09:18 AM   #2
Rewards Points: 4,806
we'd make 1 cut the 20' length & 1 cut the short 16' width which will effectively divide the slab into 8' x 10' pieces,,, we would also saw 2" deep the same day of the pour,,, all that being said, concrete knows no particular time WHEN the contractions joints need to be done OTHER than when its the right time what that means is experience tells 1 when to saw,,, we use an asphalt blade for wet OR dry sawing however we also mist the blade when dry sawing.
mesh MUST be placed at the vertical midpoint +/- 5% ( .333" ),,, mesh will add strength to the conc making it more resistant to the force of tension,,, after the conc has cured, mesh only holds the broken pieces together
Old 06-09-2011, 12:22 PM   #3
Rewards Points: 1,232
25% of the thickness.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 06-10-2011, 10:53 AM   #4
Concrete & Masonry
Rewards Points: 638
Yup, 25% minimum, or 1.5" deep in your case. It certainly doesn't hurt to saw a little deeper at the ends and intersections of the cuts either. As stated, timing is also very important.
jomama45 is online now   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 07:54 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
