Old 11-05-2009, 11:15 PM   #1
Default Concrete question
I have a question for the concrete experts here.
Is it possible to pour concrete as two separate pours and have the second pour bond to the first pour as though it were a single pour. The second would be on top of the first.
The reason for this is that I’m pouring a small footing for a small (about 18” – 24” high) side wall. The original soil had a slope. I removed the slope for the footing trench but this means one side of the trench is higher than the other. I was planning to pour a step shaped footing with the lower step forming the base for the wall and the upper to rise up to the higher level on the other side to form a small retainer (reinforced with vertical rebar).
However, I was only planning to place a wood form on the lower side (lengthwise) and let the concrete fill upto the dirt on the other sides. So this poises a problem for making a form to pour the higher “step” ssince there will be no support under the form so I was wondering if I could let the lower part cure first and then use that as a support for the form for the upper step.
blue_can is offline   Reply With Quote
Old 11-06-2009, 07:35 AM   #2
The two pours will not bond as one, nor be the same strength. If this must be done, then rebar needs to be used to tie the two sections together and a bonding agent used.
Old 11-06-2009, 03:18 PM   #3
Thanks for the reply Bob. I was curious on what they do for big projects involving concrete (say the construction of a dam). I guess it takes months to complete project like that rather than 1 hour. What techniques to they use to bond all the concrete together - is it the same as what you mentioned.
Old 11-06-2009, 04:47 PM   #4
Civil Engineer
Under certain circumstances, it is necessary to have a continuous concrete pour. This is known as a monolithic pour, and if it involves a lot of concrete (say a dam or a bridge abutment), a lot of engineering goes into the design of the pour. If it is not essential to have a continuous concrete structure, the pours are separated by a joint, and we simply accept that the concrete is not going to be continuous across the joint.
If the structure is steel reinforced, the steel is almost always continuous across the joint, so the joint carries moment and shear via the steel reinforcing. The concrete carries compression load only, so the fact that the concrete is not continuous is not normally a problem (since the steel reinforcing is continous).
For residential construction, the only purpose of the steel reinforcing is for crack control of the concrete, therefore joints in the concrete walls are not a serious problem, as long as the joint is filled with a waterproof material.
Old 11-06-2009, 05:05 PM   #5
I used to work on silos. Once the concrete pour stops it does not end until the job is complete. No separate pours are done on commercial work as a rule.
Old 11-06-2009, 07:04 PM   #6
Old School
Willie T's Avatar
Here in Florida, almost all footings that require a "step" are poured by simply beginning your pours at the lower portion of the step. Then you finish off the rest of the lower stuff, and then move on to the upper portions. Using properly stiff concrete, the lower parts will have set enough to stay in place when the uppers are "gently" poured.
This is how stepped-down garage slabs are poured. Also stairs...... from the bottom, up. The concrete will bond to concrete poured 15 or 20 minutes earlier with no problem... just the weight helps in that.
Willie T
More On This Topic
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
People enjoy cooking on barbecues, but often get frustrated with the lack of space to work with. Building a counter around your barbecue adds space to set food, dishes, drinks and other items you need. You can also incorporate useful additions like... Read More »
Now that we have our four by four posts in our prepared hole with our concrete and our water I will continue to pour our Ready Mix concrete into our hole mixing it with water. While I am doing this I will continually check my plumb line and my level here... Read More »
Sawcutting concrete can prevent driveway and walkways from cracking while allowing you to add various designs, such as diamonds and stars. You can use this technique to maintain the quality of your concrete for years. Read More »
How many bags of concrete do I need? Willie T How To Guides 5 11-09-2009 09:46 PM
concrete question hidden 1 Building & Construction 1 08-02-2009 08:02 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 02:21 PM
Bathroom subfloor on concrete slab question Mikedks Flooring 2 02-20-2008 09:28 PM
Concrete question Daniel O'Connor General Discussion 1 11-22-2004 04:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
