Concrete Problem in Basement!!
I believe basement floor is quite hard to be level as the second or first floor... in fact... may be it is on purpose to let water flow into the drain at the center... or by code...etc....
but not being level is not really end of the world as long as we are not talking about huge unlevel here...
carpet for sure has no problem
other types of flooring also has quite some tolerance and generally is ok without levelling....
for a large area to level... don't know how much it costs... probably very expensive.... buy for sure a pain to do...
if you insist 100% level... I might as well setup a plywood platform... probably about the same cost... then you can work with wood in your flooring...
