Concrete Post Holes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2010, 02:54 PM   #1
Concrete post holes
I am setting corner posts for my fence. I am using rail road ties and will be making the holes 3 feet deep by 10 inches in diameter. I am trying to decide how many bags I will be needing. I want to fill the holes all the way up with Concrete. I will be using 80lb bags. any help will be appreciated.
Thanks,
Clayton
cambishop is offline   Reply With Quote
Old 05-25-2010, 03:27 PM   #2
A 10" hole 3 feet deep is 1.63 cubic feet
A tie that is 8" by 8" (3 feet in hole) is 1.33 cubic feet
A tie that is 6" by 6" is 0.75 cubic feet
If you do a 10" hole with 8" ties you will only have 1" on either side, which is pretty minimal, so in that case I would go with a 12" hole which would be 2.36 cubic feet.
The bags should tell you how many cubic feet they make so:
Post Size - Hole Size
6" - 10" = 0.89 cubic feet per post
8" - 10" = 0.30 cubic feet per post
8" - 12" = 1.02 cubic feet per post
and if it were me, I would then add 10%
Troglodyte is offline   Reply With Quote
The Following User Says Thank You to Troglodyte For This Useful Post:
cambishop (05-25-2010)
Old 05-25-2010, 03:40 PM   #3
just checking.
So if I am reading this correctly two 80 lb bags per hole should be enough.
Old 05-25-2010, 05:05 PM   #4
Depends which set of dimensions you are using, if you are going 8" railroad tie in 10" diameter hole, and your 80lb bag represents 0.66 cubic feet then you two holes per bag. If you are going 8" - 12", then 2 bags covers three holes.
Old 05-26-2010, 08:12 AM   #5
checking one more time
I apologize for having to clarify again, I am definately not a math wizard so I am glad you are. I am doing my posts with an 8 inch rail road tie, 3 feet deep and 12 inches in diameter. That would require less than one bag to fill the hole?
Pole barn footing question Badfish740 Building & Construction 12 08-21-2011 09:06 AM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 05:03 PM
post hole concrete handifoot Building & Construction 5 08-31-2009 07:36 AM
forming holes in surface of wet concrete mx13 Landscaping & Lawn Care 1 04-25-2008 05:06 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 10:50 AM
