Concrete Porch Slope - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 08:26 AM   #1
Concrete porch slope
What is code for the slope away from the house for a concrete porch?
Doris56 is offline   Reply With Quote
Old 06-20-2011, 09:05 AM   #2
Concrete & Masonry
Rewards Points: 530
There is no code, per se, that I've ever seen, but the industry standard on concrete is "typically" 1/4" per foot on exterior flatwork. Certainly 1/8" per foot is the absolute minimum. If it's a covered porch, it's usually acceptable to be between those two ranges.
jomama45 is offline   Reply With Quote
Old 06-20-2011, 09:27 AM   #3
OK. So how would a vinyl railing be installed so that it doesn't look really slanted? Can the railing be leveled?
Old 06-21-2011, 09:59 AM   #4
Concrete & Masonry
Rewards Points: 530
The top rail needs to run level, regardless of the pitch. You may need to alter the height of the spindles to retain a consistent spacing under the railing if the pitch is drastic.
Please help with concrete front porch and step mdambrosio Building & Construction 6 05-26-2011 08:48 AM
concrete porch settled from house, cracks slash5bmw Building & Construction 5 06-30-2010 11:06 AM
Concrete Porch & Limestone Threshold Karen5 Building & Construction 1 06-02-2010 04:06 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
Do I need to slope my concrete patio if I am covering it? diyintexas Building & Construction 2 09-29-2009 04:02 AM
