Concrete Porch Settled From House, Cracks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 01:13 PM   #1
Rewards Points: 150
concrete porch settled from house, cracks
I have a concrete porch that I'd like to patch. I can't afford to demo it right now but I'm having some water issues in the basement when it pours.
Someone recommended backer rod to stuff the cracks and then use ardex.
I went to home depot and the guy there recommended a patch mix.
I was thinking about putting gravel into the cracks until about 1/2 inch from the surface and then using a patch concrete.
I'm more concerned about stopping the water from getting into the basement so I'd like to fix the top of the porch and the part that used to contact the house. This is a 70 year old home in Baltimore.
The crack in the middle of the porch used to have moss growing in it but I pulled it all out today. The concrete was very soft underneath.
I'm not sure if I should scrape as much of the old concrete off or if that will just make a bigger job.
Please take a look at the photos below.
Any advice would be greatly appreciated. I'd like to get it patched before it rains again.
http://picasaweb.google.com/lh/sredi..._ED&feat=email
http://tinyurl.com/26tpl3m
Slash
slash5bmw is offline   Reply With Quote
Old 06-29-2010, 05:17 PM   #2
Rewards Points: 4,534
1st off, NEVER pay any attn to guys who wear aprons nor whoever recommended ardex fer-gawd's-sale
backer rod is used to provide shape factor to jnt/crk sealants,,, NEVER place incompressibles into crks OR jnts,,, repeat NEVER ! ! ! main reason most apron guys still give out free advice is because NO ONE EVER SUES 'EM ! ! !
btw, that crk's gotta be dry to seal it properly.
Old 06-29-2010, 06:35 PM   #3
Civil Engineer
Rewards Points: 4,566
That porch is a mess, looks like it settled due to inadequate foundation preparation. That said, if you want to make it look more cosmetically appealing, you should jackhammer out the bad concrete, and patch with bag mixed concrete. Check out the Thoro Corporation, they have a variety of mixes for repair of damaged concrete.
Patching will not stop the concrete from continuing to settle and crack, but it will make the porch look better for a while. Ultimately this is a demo job, followed by preparation of a suitable base, which means removing all unsuitable soil and backfilling with structural fill (read crushed stone).
Old 06-29-2010, 10:04 PM   #4
Rewards Points: 150
Daniel and itsreallyconc,
Thanks for you replies. I know the porch is in bad shape. It's 70 years old. I'm not sure what the cost would be to demo and rebuild but it's probably more than I can spend right now.
Daniel, you mention to used bag mixed concrete. I think I can get this at home depot. Should I chip out all the old concrete that easily falls off?
Should I fill the deep cracks with gravel before I pour the bag mixed concrete into the deep cracks?
The porch is about 4 feet above the ground and I think the concrete will drop to the bottom and it will many bags before the crack is filled.
There was rebar broken and exposed when I was examining the crack.
Is this the Thoro corp you mentioned?
http://www.thorotechnology.com/
Thanks again.
Slash
Old 06-30-2010, 09:23 AM   #5
'85 k100rs euro spec - '74 r80/6 - 82 r100rs - no /5
for best results, diamond saw the patch & pick up some acrylic latex bonding milk,,, don't forget to restore the jnt, either,,, chip off ALL the damaged 'crete.
thoro or sonneborn - not avail at any apron sture !
Old 06-30-2010, 11:06 AM   #6
Rewards Points: 150
itsreallyconc,
Do you recommend muriatic acid or tsp to clean the concrete crack before I pour in the cement?
Thx
Slash
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 03:53 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
what flashing to use on flat concrete porch exqssme General DIY Discussions 3 07-25-2009 07:09 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
