Concrete Porch Moving - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 06:53 AM   #1
Concrete Porch moving
My small concrete porch is moving away from the wall due to ground settling. This is leaving a gap that allows blowing rain to get behind the steps and the water seems to be leaking into the bricks in the basement. Any suggestions how to fill the space? or Repair without tearing down the porch?
cabw6047 is offline   Reply With Quote
Old 09-10-2011, 07:05 AM   #2
Rewards Points: 5,336
Very hard to repair an inadequate base. Is this house in a clay soil area with drought conditions?
How big is the gap?
Has the porch stopped moving?
Look at a product from the Sika company. There are others, but this is the one I use.
Ron
B. Franklin 1759
Old 09-10-2011, 08:05 AM   #3
Civil Engineer
Rewards Points: 4,854
You have two essentially separate issue. First, your porch is settling unevenly, else the house is settling making it look like the porch is settling. Solving that problem is complex, and would require you to completely remove the porch, properly prepare the base, then rebuild the porch. There are expensive alternatives such as mud jacking, minipiles, or helical anchors, but these are expensive solutions not appropriate for a small porch.
The second problem is simpler to address. You need a flexible sealant between the porch and the house to prevent water from draining between the porch and the house, and getting into your basement. This should have been handled by proper flashing of the gap between the porch and the house when the porch was installed, but I have seen many installations with no flashing, which could be your problem. Installing flashing without removing the porch is likely to be impossible, so the next best option is to seal the gap annually using a polybutyl sealant. Flexible, tough, waterproof, adheres well to concrete. Since your porch is likely to continue settling, you will need to reseal annually at least, but much less expensive than tearing out the porch and starting over.
If you do rebuild the porch, make sure you properly flash the house where it meets the porch.
repairing cracks in a concrete porch and stairs. mpkchiucago Building & Construction 0 08-12-2011 09:31 AM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
Concrete Porch & Limestone Threshold Karen5 Building & Construction 1 06-02-2010 03:06 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
covered concrete porch..what kind of floor? captjackny Flooring 4 02-26-2010 10:47 AM
