Concrete Pillars - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 10:18 AM   #1
concrete pillars
I am building an addition 24 X 40 to my existing cabin this fall. In the spring the ground is wet and is mainly clay. I was thinking about supporting the structure with pillars in 4 to 5 feet of concrete below the frost line with treated 6 x 6 posts to support the floor and building but I am not sure if that is a good idea or how many pillars I would need to support the structure. I am afraid of using a slab due to cracking and heaving. Any Ideas
cabinguy is offline   Reply With Quote
Old 07-12-2011, 10:40 AM   #2
AGWhitehouse's Avatar
You can space them at any spacing you would like up to a reasonable point (ex. 20' spacing is way too much). You will need to size the pier diameter and beams between them based on the decided span. Snow loading, wind load, earthquake load (if applicable), dead load, and live loads play a part in determining the beam size.
Slabs on grade can be insulated along the edges to protect from frost. Most areas have building codes that require it. If designed and built properly, a slab can remain solid for a very long time.
AGWhitehouse is offline   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 08:54 AM
