Concrete Pillar Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 11:42 AM   #1
Rewards Points: 14
Question
Concrete pillar foundation
We are going to be building a 16x24 cabin with a loft and will be using sonotube concrete forms for the footings. How far apart should they be spaced, how far below the frost line (10 inches), and how far above the ground would you recommend?
Also, we are plannig on renting either a bobcat with an auger (50hsp) or a mini skid-stear (20hsp). Our soil is really stoney so we're wondering which one would probably be best? Would the smaller one be sufficient?
Gaugesquared is offline   Reply With Quote
Old 07-19-2012, 04:55 PM   #2
Civil Engineer
Rewards Points: 4,962
The spacing of the sonotubes is determined by your foundation design, specifically how big the beams are going to be. The tradeoff is that larger beams cost more, but the spacing on the sonotubes is greater. The required size of the tubes depends on your soil conditions, and the load on each support. You need to do some soil sampling before you can size the tubes, unless you go with minimum sizing from the local building code.
Required depth of the footings is typically based on local building code, check with your local building inspector. Often the building code will dictate the sizing and connection details for all structural elements, best to check with the building inspector. If there is no building inspector, or you are not required to pull a permit, it is generally safe to design to the building code for your state or province.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Gaugesquared (07-19-2012)
Tags
concrete , footings , foundation concrete , pillars , sonotube
Repairing a concrete foundation corner. Timlo Building & Construction 4 10-11-2011 10:40 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Basement concrete foundation wall insulation question pameyer Building & Construction 0 01-28-2011 12:05 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
Concrete Block Foundation Questions project_guy Building & Construction 1 05-09-2008 09:16 AM
